Where can I find a direct swap treadle valve for a B model. I don't really want to retro fit lines/fittings. Most of the newer treadle valves I have seen have 4 fitting holes, 2 on each side, were as the one from the B model has 3 fittings in back and 1 in the front.
Thanks
Try Watt's Mack. Daniel
https://www.bigmacktrucks.com/topic/13733-treadle-valve/#findComment-54463
