Sounds like the electrical connections behind the horn button located within the steering wheel are needing adjustment. I'm assuming the horns are electrically actuated and slaved to the horn relay under the dashboard. I've seen this several times through the years with the electric horns but have never dealt with an electrically actuated air horn setup. The theory however, is the same.
Electric wire from the horn button had cracked insulation and contacted steering shaft when turning right. A little electrical tape and now enjoy quiet right turns.
Good on ya.
