What is the inlet size on the top of the air filter for the tip turbine motors... I know they use a larger size to help feed the tip turbine and turbo from the same filter.
If you ever noticed,,,,the front mount air to air 300s have a smaller filter inlet than a 285 charge cooler filter....
https://www.bigmacktrucks.com/topic/14263-r-model-tip-turbine-air-cleaner/
I think mine is 7".
