Does anyone know if an NTC cummins block will drop-in to an old mack. It is a B735 with an NH 220 hp Cummins inher now. I think all these blocks were the 855 c.i. block so I thought it might be an easy re-power without moving the firewall. Any info would be appreciated.
barry
https://www.bigmacktrucks.com/topic/1441-cummins-drop-in/
All the big block Cummins motors-H,NH,NTC,NTA are the same size externally, and will fit, may be some minor differences in accessories, that's all.
Thanks for the help. While you are thinking about it, do you think a TRT trans and camel back rears would stand up to 400 hp. In the old days they always said the camelbacks were indestructible - but they hadn't seen 400+ hp in those days either. I have driven a quad box with NTC 335 hp, so I know the drive line will take that much. Thanks again
barry
https://www.bigmacktrucks.com/topic/1441-cummins-drop-in/#findComment-7155
  • 3 weeks later...
