Buck,
You should be OK changing to 2 - 12V batteries. Use the best you can buy group#31 950 or 1000 CCA. I run my R model with 2 batteries and have never had a problem. Just be sure the starter and the wiring is in good shape. One battery per box will do it or two in one box wired in parallel not in series like the six volt.
Chuck
