The valves on number 8 are noisey. Like not ticking but louder than the other 3 heads. I ran this engine for 9 hours
then reset the valves.Still seems to loud for me. Is this normal when you have new piston and liner.
Any suggestions.
Thanks
No I think you may not be set right check to make sure you are on the right cyl when setting 8 and 2 are on the same mark. 2 should be on overlap when you set 8
https://www.bigmacktrucks.com/topic/15441-engine-knock/page/2/#findComment-63653
I have two good, inspected take-off cylinder heads. Give me a ring, we'll work out the details.
603-239-7008
Thanks,
Phil
I didin't read far enough to where you found some. Disregard. Have a good day.
Thanks,
Phil
phil@globaltrucktraders.com
www.globaltrucktraders.com
603-239-7008
https://www.bigmacktrucks.com/topic/15441-engine-knock/page/2/#findComment-63654
