One of our members had this in a post from a recent show, Never saw a B with this type of nose. Is it factory and anybody know what powers it? Or is it a set back axle? Also got th new drive chains for my AC today.......now just need 1 adjuster and 1 drive sprocket. :thumb:
https://www.bigmacktrucks.com/topic/15506-long-nose-b/
In the mid 60s i remenber two of those coming in and one had a engine repower with a 6 71 DD in it . The other had a cat repower way before i remenber trucks coming from the factory with a cat engine in it. It was a equipment cat engine.The best i remenber the only thing different from a B 61 body was the rad and cowl was exstend forward.
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-62592
Yup.
Longer hood to make room for a Cummins, with steer axle in the same location as a B61, rather than set forward like a B75.
Kinda the same but different I'm doing with my white B61. I've "split" the grille shell and going to weld in an extension of five inches to bury a CAC, and a/c condensor behind non functioning, cable operated shutters. The engine is an E6-350.
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-62593
Cool I like that ideal but i looked into that with mine years ago and ended up installing the Cac on the front out side . The fan is so short on a B61 that even when you do get the speed up on it it is so loud whith noise. I used a 6 blade fan on a swister clutch and it was even more louder.The problem with the narrow rad is the short fan has to be used.
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-62599
  • 3 weeks later...
I never knew Mack ran the Hall Scoots in the B models . Thanks for the link and new knowlrdge. Paul
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-63535
Mack manufactured some larger pump B models that the 707 engines could not power. The noses were lengthened to accomodate a Hall Scott engine. Scroll down this link to see one. http://www.lastresortfd.org/museum.htm mack458
I don't recall seeing one of those either. Do you know the model number? It appears to be built with the same parts as a B-71.
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-63709
That's a B-21. Mack only made 9 of them. All 9 were fire trucks. Basically it is a B-75 with the B-71 extended grill
so they could fit the big Hall-Scott under the hood.
Thanks, Josh :mack1::SMOKIE-LFT:
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-63718
more info-
I saw one of these when i was a kid,did'nt think much of it at the time,the guy ran it out of new jersey,not far from where i used to live, pulled an old 35' BROWN reefer with it,seems to me my dad said he ran florida to phila.PA once a week . He also had a B-61 integral sleeper sitting behind his house,long gone now,the last time i was by there,there was a new shopping center where the trucks were parked........Mark
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-63737
  • 13 years later...
This is a Mack model B-71 which came out in 1953, when all of the new B series came out. This model may have the Cummins NH-220. The early Cummins 673 CID six had a 4-7/8 in bore by 6 in stroke, the successor the 743 CID six had a 5-1/8 in bore and 6 in stroke and the successor to the 743 CID six was the Cummins NHC which were 5-1/2 in bore by 6 in stroke with 855 CID. Foe a short period Cummins made the Super 250 which displaced 927 CID, same 5-1/2 bore but deeper stroke/sleeve.
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-551172
On 5/6/2024 at 10:24 AM, skydawg said:
Someone posted maybe 2 yrs ago,he bought two of the Hall Scott pumpers.He was gonna restore one,I don`t think he`s been on here in a long time.
that would be MorrisMe. they were B21's, both from seattle fire. have the giant Hall Scott engines.
his last log on was 2-23-24
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-551282
They both seem to be in real good shape forgot all about that guy till you brought it up… bob
https://www.bigmacktrucks.com/topic/15506-long-nose-b/#findComment-551369
