Hi, folks--
I'm new to the board... :SMOKIE-LFT:
The company I work for is getting around to scrapping some old mid-80's Midliners. Before they go, I'd like to salvage the Bulldog ornaments off the noses. The heads of the bolts that secure the dogs' hind paws look like two opposing triangles. Is there a special bit or driver that is required to remove these bolts? What is it called? :bulldog1:
Thanks for any advice.
https://www.bigmacktrucks.com/topic/1571-removing-mack-bulldog-ornament/
It sounds like a clutch head screw. Most bit sets have one in them, or can be bought at sears or most any hardware store with a gook tool selection. You may want to spray them with some penetrating oil before you attempt removing them. Good luck!
:mack1::mack1:B)-->
QUOTE(Johnny B @ Sep 26 2006, 09:30 AM)
Hi, folks--
:mack1: After working at it for a hr with busted nuckels and broken bits and drill bits i used a sawsaw, but it looks good hanging on the wall
