What this truck is suppose to be? 1M2AY83Y6MM005601
Cut and paste of the chassis VRI...
MODEL: RW713
GSO: E065744B
SERIAL RANGE: 005600-005601
FIRST BUILD DATE:
06/26/90 1M2AY83Y4MM 005600 (See End of VRI for Other Dates)
FRAME: RAILS, CROSSMEMBERS, SUPPORTS, BRACKETS
38QL 41P5 CROSSMEMBER ARRGT,FRT SPRG RR BRKT
31QL 5119P14 FRAME ARRGT,BASIC(6100MM WB)
34QL 4128P7 FRAME ARRGT,FRT
35QL 4106P3 FRAME ARRGT,RR
173QL 31 FRAME MODIF,SIDERAIL CU(FOR REFERENCE ONLY)
173QL 32 FRAME MODIF,SIDERAIL CU(FOR REFERENCE ONLY)
32QL 216M FRAME MODIFICATION,UNUSED BOLT HOLES
28QL 52 REAR CROSSMEMBER ARRGT
22QL 4649 SUPPORT ARRGT,FRONT FRAME
SUSPENSION: SPRINGS, BEAMS, SHOCKS, TORQUE RODS
1QK 5581P8 FRONT SPRING ARRGT(3 LEAVES)
3QK 5622P4 REAR AIR SPRING SUSPENSION ARRGT
FRONT AXLE: KNUCKLES, BEARINGS, SEALS, BRAKES, CHAMBERS
45QH 51P8 BASIC FRONT AXLE ARRGT(SEE SERVICE KIT
83QD 42P2 BRAKE ARRGT,FRT AXLE(16.5" X 5.0")(Q SERIES)
84QD 32P2 BRAKE CHAMBER AND SLACK ADJUSTER ARRGT,FRT
46QH 41P4 FRONT AXLE WHEEL SEAL AND HUB CAP ARRGT
REAR AXLE: HOUSING, BEARINGS, SEALS, CARRIER, BRAKES, CHAMBERS
53QF 567P6 AXLE ARRGT,RR RR
11KH 5432P3 AXLE CARRIER ASSY,FRONT REAR(CRDPC92)(4.17R)
85QD 432P2 BRAKE ARRGT,RR RR AXLE
86QD 443P17 BRAKE CHAMBER AND SLACK ADJUSTER ARRGT,RR AXLE
72QF 41P6 FRONT AXLE OIL SEAL ARRGT
53QF 566P6 FRONT REAR AXLE ARRGT
85QD 431P2 FRONT REAR AXLE BRAKE ARRGT(SS441C SERIES)
11KH 5444P3 REAR REAR AXLE CARRIER ARRGT(CRD93)(4.17R)
WHEELS: RIMS, HUBS, DRUMS, BEARINGS
43QJ 32P17 FRONT DISC WHEEL ARRGT(24.5"X8.25")(ALUMINUM)
47QJ 32P47 FRONT DISC WHEEL HUB AND DRUM ASSY
45QJ 33P14 REAR DISC WHEEL ARRGT(24.5"X8.25")(ALUMINUM)
49QJ 32P63 REAR DISC WHEEL HUB AND DRUM ARRGT
DRIVE SHAFT: DRIVE LINES, YOKES, BEARINGS
288MU 42P21 DRIVE SHAFT ARRGT,FRONT W/CENTER BEARING(DANA
122MU 419M3 FRONT CENTER BEARING SUPPORT ARRGT
230MU 41P17 INTERAXLE DRIVE SHAFT ARRGT(DANA 1810 HD
288MU 43P- REDIRECTED FROM 288MU 43P20
PROPELLER SHAFT ARRGT(1880 SERIES)
288MU 41P26 PROPELLER SHAFT ARRGT(DANA 1880 SERIES)
125MU 51P36 REAR AXLE YOKE ARRGT
120MU 53P20 TRANSMISSION YOKE ARRGT(TYPE I)
122MU 420M5 YOKE AND INTERMEDIATE BEARING ASSY,1ST INT/M
AIR: PIPING, VALVES, RESERVOIR, BRAKE, CONTROLS, STARTER, HORN, CAB SUSP MTG
65QE 524P20 AIR BRAKE ARRGT,AUX SPRG TYPE CONT
55QE 410P2 AIR BRAKE ARRGT,MAN/AIR CONT VLV
66QE 31 AIR CONTROL VALVE AND BRAKE PEDAL ARRGT
13QE 492P3 AIR DRYER ARRGT
38MR 4167P2 AIR HORN ARRGT(RECTANGULAR SINGLE TRUMPET)
22QE 5356P9 AIR RESERVOIR ARRGT
50QE 42P3 BASIC CAB AIR BRAKE PIPING ARRGT
51QE 57P9 BRAKE ARRGT,CHASSIS
30QE 4620 BRAKE ARRGT,HAND CONTROL VALVE
10MX 42 CAB CLUTCH CONTROL ARRGT
61QE 31P2 COMPRESSOR DISCHARGE LINE PIPING ARRGT
53QE 41P2 CONTROL ARRGT,TRAILER BRK
11MX 49P2 CONTROL ARRGT,TRANS CLCH
72QE 41 FRONT AXLE AIR BRAKE FLEX HOSE PIPING ARRGT
20QE 3228P2 GOVERNOR MOUNTING ARRGT
54QE 49P9 HOSE AND STOWAGE ARRGT,TRAILER CONN
228QS 48 ISOLATED CAB MOUNT PIPING ARRGT
14QE 42P2 PIPING ARRGT,AIR APPLICATION GA
62QE 43 PIPING ARRGT,AIR COMPRESSOR INTAKE
76QK 543P4 PIPING ARRGT,AIR SUSP
73QE 482 PIPING ARRGT,BOGIE BRAKE
69QE 31P2 VALVE ARRGT,AIR CONT QUICK REL
67QE 45P4 VALVE ARRGT,PWR DIV AIR CONT LKOUT
STEERING: GEAR, SHAFTS, PUMP, DRAG LINK, PIPING
1QC 51005P5 GEAR MOUNTING ARRGT,STEER
2QC 5103P2 POWER STEERING PIPING ARRGT
1QC 51016 SHAFT ARRGT,STEERING
1QC 4540P7 UPPER STEERING COLUMN MTG
EXHAUST: ENGINE, CHASSIS, TURBO UNLOADER, MUFFLER
15ME 544P30 MUFFLER ARRGT,EXH
29ME 21P5 RAINCAP ARRGT,VERT EXH
14ME 575P2 VERTICAL EXHAUST PIPING ARRGT
ELECTRICAL: LAMPS, SWITCHES, GAUGES, PANELS, WIRING, HARNESS, SENDING UNIT
86MR 31 ACCESSORY RELAY ARRGT(12 VOLT)
44MR 515 CAB WIRING ARRGT
57MO 22 CENTER DOME LAMP ARRGT
11MS 55 COMPUTER MODULE ARRGT,ENGINE CONTROL
16MR 24 CONNECTOR SWITCH ARRGT,BASIC PRESS SENSING
14MR 45 DIRECTIONAL SIGNAL SWITCH ARRGT
17MS 436P4 EQUIPMENT ARRGT,ELEC OPTIONS
17MS 452P2 EQUIPMENT ARRGT,ELEC(SLEEPER OPTION)
17MS 568P3 EQUIPMENT ARRGT,ELECTRICAL INT CAB
97MR 31 FIBER OPTIC RECEPTACLE ARRGT
56MO 29308 FRONT REFLECTOR MOUNTING ARRGT(AMBER)
74MT 56P17 GAUGE PANEL ARRGT
74MT 56P20 GAUGE PANEL ARRGT(PANEL "D")
74MT 56P32 GAUGE PANEL ARRGT(PANEL "D")
71MT 419P10 GAUGE PANEL ARRGT(PANEL-A)
73MT 436 GAUGE PANEL ARRGT(PANEL-C)
74MT 56P12 GAUGE PANEL ARRGT,PANEL D
74MT 56P14 GAUGE PANEL ARRGT,PANEL D
74MT 56P16 GAUGE PANEL ARRGT,PANEL D
74MT 56P6 GAUGE PANEL ARRGT,PANEL D
74MT 56P8 GAUGE PANEL ARRGT,PANEL D
74MT 56P21 GAUGE PANEL ARRGT,PANEL-D
74MT 56 GAUGE PANEL ARRGT,PANEL-D
74MT 37 GAUGE PANEL ARRGT,PANEL-D-BASIC
71MT 36P3 GAUGE PANEL ARRGT,PNL A IND LMP
1MO 474 HEADLAMP ARRGT(DUAL RECTANGULAR)
75MT 312P2 LOWER CONSOLE GAUGE PANEL ARRGT(WITH TRAILER/
73MT 437P4 PANEL ARRGT,GA PNL C
73MT 437P3 PANEL ARRGT,GA PNL-C
72MT 418P2 PANEL ARRGT,GAUGE(PANEL B)
52QR 459P2 PANEL ARRGT,INST
4MR 2384P2 PYROMETER NAMEPLATE ARRGT(1075°F)
45MR 312 PYROMETER WIRING BANDCLAMP ARRGT
36MT 425P14 RADIO ARRGT
13MR 32 SWITCH ARRGT,TILT RAY
17MR 33P3 WARNING ARRGT,BUZZER
101MR 31P2 WIRING ARRGT,CAB SLEEPER BOX
8MR 51054 WIRING DIAGRAM,SLEEPER BOX
8MR 51081 WIRING DIAGRAM
ELECTRICAL: LAMPS, REFLECTORS, HORN, ACCESSORIES AND WIRING
174MS 42P2 ANTENNA ARRGT,CB RADIO
83MR 42P2 CAB TO HOOD WIRING ARRGT(W/AIR CONDITIONING)
18MS 41 CIRCUIT BREAKER MOUNTING ARRGT
60MO 49 CLEARANCE AND IDENTIFICATION LAMP ARRGT
18MS 52P7 ELECTRIC FIREWALL EQUIPMENT ARRGT
54MR 311 ENGINE HEATER CONNECTOR ARRGT
45MO 37 FRONT DIRECTIONAL SIGNAL ARRGT
38MR 3147P2 HORN ARRGT,ELEC
18MS 53P2 JUNCTION BLOCK MOUNTING ARRGT
175MS 34P2 RADIO ANTENNA ARRGT
36MR 42P6 SEMI-TRAILER CABLE ARRGT(WITH PLUG)
93MR 41P3 WIRING ARRGT(HARNESS TEMPERATURE GUAGE)
82MR 42 WIRING ARRGT,HOOD
99MR 42P2 WIRING ARRGT,SLEEPER BOX
63MR 34P2 WIRING ARRT,HEATED MIRRORS
ELECTRICAL: ALTERNATOR, STARTER, BATTERY AND RELATED ENGINE WIRING
1MJ 5507P18 ALTERNATOR ARRGT(14 VOLT/100 AMP)
1MK 4500P13 BATTERY BOX ARRGT
46MK 3698 BATTERY CABLE ARRGT(12V NEG GND)
8MJ 4288P3 ELECTRIC STARTER MOTOR ARRGT
67MR 47P2 ENGINE AND TRANSSMISSION OIL TEMPERATURE
64MR 410 ENGINE HEATER WIRING ARRGT
9MR 21P3 NAMEPLATE,BATTERY SERVICE WARNING(NEGATIVE
62MO 427 REAR COMBINATION LAMP ARRGT
67MR 47 WIRING ARRGT(ENGINE OIL TEMPERATURE)
48MR 36P6 WIRING ARRGT,CHASSIS RR
66MR 513 WIRING ARRGT,ENG
62MR 46P3 WIRING ARRGT,HEATED AIR DRYER
ENGINE: MTG, CLUTCH, AIR CLNR, FAN, HEATER AND AIR COND. PPG, COND COMPR
28MD 21P4 AIR CLEANER ARRGT
32MD 48P2 CHARGE AIR COOLER PIPING ARRGT
500GB 4203 CRANKCASE OIL LEVEL INDICATOR ARRGT
30MD 517 ENGINE AIR-FILTERED INTAKE ARRGT
114RD 313 ENGINE BLOCK HEATER ARRGT
1MH 348P8 ENGINE FAN MOUNTING ARRGT(VISCOUS DRIVE)
15QL 3269 ENGINE MTG ARRGT
11GB 76434 ENGINE,E7-400-4VH(1990 EPA)
203RD 464 FREON COMPRESSOR ARRGT
45QL 3212 FRONT ENGINE MTG ARRGT
50MD 41 INDICATOR ARRGT,AIR CLN RESTRICTION
22MD 48 MANIFOLD PRESSURE GAUGE PIPING ARRGT
238GC 4112 OVERBOARD BREATHER TUBE ARRGT
202RD 58P3 PIPING ARRGT,AIR CONDITIONER
1RD 370P4 PIPING ARRGT,HTR
17QL 415 TIE ROD ARRGT,FRM
15MT 3235 TUBE ARRGT,OIL PRESS GAUGE
TRANSMISSION: MOUNTING, SHIFTER, CLUTCH MOUNTING
11HB 4200P2 CLUTCH DISC MOUNTING ARRGT(2"-10 SPLINE)
2RT 323P2 CLUTCH RELEASE BEARING LUBE ARRGT
34MY 421P4 PIPING ARRGT,GR SHIFT(AIR CONT)
33MY 48 SHIFT ARRGT,GEAR(W/O FWPTO)
8MY 411 SHIFT STICK SEAL ARRGT
11KB 51432 TRANSMISSION ASSY(T2130/T2180)(13/18 SPEED)
31RG 4561P2 TRANSMISSION COOLING PIPING ARRGT
60QL 357P3 TRANSMISSION MOUNTING ARRGT
FUEL: TANKS, MOUNTING AND PIPING
483GB 361 FUEL FILTER MOUNTING ARRGT(SECONDARY)
3MB 41971P6 FUEL PIPING ARRGT
1MB 41132P4 FUEL TANK BRACKETS MOUNTING ARRGT(ALUMINUM)
16MB 48P22 TANK UNIT,FUEL GAUGE(25" DIA. ROUND TANK)
COOLING: RAD'R, PIPING, GRILLE, CHARGE, AIR COOLER AND RELATED AIR COND GRPS
3MG 491P2 CONTROL ARRGT,SHTR
4MD 42 COOLER ARRGT,CHARGE AIR
1MF 51222P9 RADIATOR ARRGT
21MF 56 TIE ROD MOUNTING ARRGT,RADR
CAB: GROOMING, DOORS, SEATS, HEATER AND A/C, MIRRORS, MTG, WIPERS AND WASHER
34RC 468P2 BELT ARRGT,SAF
34RC 572P21 BELT MOUNTING ARRGT,SAF
86QS 57P6 BOX ARRGT,SLEEPER
1QS 51027P4 CAB COMPLETE,CAB IN WHITE
3QX 520P2 CAB DOOR GROOMING ARRGT(LH)(MANUAL WINDOW
3QX 519P2 CAB DOOR GROOMING ARRGT(RH)(MANUAL WINDOW
71QS 4103 CAB INTERIOR AND EXTERIOR SEAL ARRGT
4QS 5126 CAB MTG ARRGT
34RC 1106 DOOR AND IGNITION LOCK CYLINDER KIT
3QS 4357P8 GROOMING ARRGT,CAB EXT
258QS 55P24 GROOMING ARRGT,CAB INT
87QS 399 GROOMING ARRGT,SLEEPER BOX
1RD 4349 HEATER AND AIR CONDITIONER ARRGT
72QS 4138P4 MIRROR MOUNTING ARRGT(LH)(HEATED AND
72QS 4137P4 MIRROR MOUNTING ARRGT(RH)(HEATED AND
6QS 4392P23 PANEL ARRGT CAB TRIM
73QS 49P8 PIPING ARRGT,SEAT
22QE 3717 RESERVOIR MOUNTING ARRGT
106QS 5105P20 SEAT ARRGT,DRIVER
106QS 5106P20 SEAT ARRGT,RIDER
85QS 44P56 SLEEPER BOX ARRGT(TYPE II,DELUXE VERSION)
85QS 43 SLEEPER BOX COMPLETE
89QS 51P3 STEP ARRGT,SLEEPER BOX
148QS 44 SUNVISOR ARRGT(EXTERIOR)
16QR 5167P30 TOE AND FLOOR BOARD ARRGT
15QT 312P2 WINDSHIELD WASHER HOSE PIPING ARRGT
32QT 571 WINDSHIELD WIPER ARRGT(12 VOLT)
ACCELERATOR: LINKAGE, CONTROLS, CABLES
2QB 4709 CAB ACCELERATOR ARRGT(MODELS W/V-MAC
HOOD: FENDERS, BUMPER, SPLASH SHIELDS AND GUARDS, STEPS (CAB)
24QL 4424 BUMPER ARRGT(FRONT)
47QM 4123 FLAP ARRGT,MUD-FRONT
1QM 5754P6 HOOD ARRGT,ENG
148QM 31 HOOD EMBLEM,ECONODYNE
141QM 416 INSULATION ARRGT,HD
47QM 486 SPLASH APRIN ARRGT,FEN
29QM 491P7 STEP ARRGT,FUEL TANK(LH)
29QM 490P3 STEP ARRGT,FUEL TANK(RH)
MISCELLANEOUS: NAMEPLATES AND LABELS
4MR 2668B DOCUMENT,INCOMPLETE VEHICLE CERTIFICATION
4MR 452P6 LABEL AND NAMEPLATE ARRGT
4MR 457P32 LABEL ARRGT(CAUTION-WINTERFRONT)
4MR 3195 LABEL ARRGT(OPERATING INSTRUCTIONS)(NEUTRAL
4MR 460P2 LABEL ARRGT,CAUTION(FRAME)
4MR 457P26 LABEL ARRGT,WARNING OR CAUTION
4MR 56P6 LABEL ARRGT,WARNING
4MR 454P4 LABEL ARRGT,WARNING(AVOID PERSONAL INJURY)
4MR 2909P3 LABEL MOUNTING ARRGT
4MR 2677P3 NAMEPLATE ARRGT(RW700)
4MR 82052 PLATE ARRGT,VEHICLE IDENTIFICATION
9RJ 313P30 SHIFT MARKER PLATE ARRGT
4MR 444P4 VEHICLE CERTIFICATION LABEL ARRGT
4MR 444 VEHICLE CERTIFICATION LABEL ARRGT
FACTORY INSTL SPECIAL EQUIPT: MISCELLANEOUS
47QM 514P13 SPLASH GUARD ARRGT
RECORDED CHANGEOVER REMOVAL
REMOVED NPN 1/4 FENDERS
CHASS # 005601
RECORDED CHANGEOVER INSTALLATION
OMN 60SS REDIRECTED FROM OMN60SS
1/2 FENDERS SS
CHASS # 005601
OMN 8060SSMK REDIRECTED FROM OMN8060SSMK
1/2 FENDERS SS
CHASS # 005601
LOCAL APPROACHES
CHASS # 005601
NPN DK RUBY RED 73031PP
CHASS # 005601
57GC 384 ENGINE BRAKE KIT
CHASS # 005601
OMN 3633GR REDIRECTED FROM OMN3633GR
FULL DECK PLATES
CHASS # 005601
01BG4810 GUIDE RODS
CHASS # 005601
NPN PAINT TOP OF CAB TRIMAC COLORS
CHASS # 005601
NPN RED STRIPE FLAME RED DU78072
CHASS # 005601
CAX 300L REDIRECTED FROM CAX300L
STEP LH
CHASS # 005601
1MR 3165 TOGGLE SWITCH(SPST)
CHASS # 005601
NPN WHITE WT0069
CHASS # 005601
Other Build Dates:
BUILD DATE: 06/26/90 1M2AY83Y4MM 005600
BUILD DATE: 06/27/90 1M2AY83Y6MM 005601
  • 8 months later...
