Ok on my mack cf 600 my fuel gauge isnt working. Its stuck on E, however the cut off switch does turn it on and off so the gauge its self works. My question is is it a stuck float? Also where is the float exactly inside the gas tank? Any one else have this problem and how did you fix it? Thanks for the help.
https://www.bigmacktrucks.com/topic/15940-fuel-tank-questions/
Look for a plate with 2 wires somewhere and screws on top of tank. Usually a universal sending unit should work.
https://www.bigmacktrucks.com/topic/15940-fuel-tank-questions/#findComment-64441
