I have a 96 Mack CH613 with a E7-427. From time to time, the speedo will all-of-a-sudden start reading exactly half the speed I'm going. It did it for a couple weeks, and then the problem went away for the most part, but occasionally it will just drop down to half-speed. There seems to be no rhyme nor reason to it. Any suggestions?
https://www.bigmacktrucks.com/topic/15954-96-ch613-speedo/
When ours does that the speedo sensor needs to be cleaned then it's good to go for another couple of years.
https://www.bigmacktrucks.com/topic/15954-96-ch613-speedo/#findComment-64496
i had a 96 ch 9spd fuller trans, had the same prob intermitten for several months, finally found yoke loose,
all i did was tighten it and every thing was fine.
https://www.bigmacktrucks.com/topic/15954-96-ch613-speedo/#findComment-64613
