Turned out to be a loose yoke behind my air-shift 6 speed, only did it between 50 and 60 with no load on the driveshaft, yoke was worn...put a new yoke, bolt and washer and she is as good as new. Hope this helps anyone trying to narrow down the cause of a driveline vibration issue.
https://www.bigmacktrucks.com/topic/16294-driveline-vibration/
