i called a friend and he said that they would work but the ratio might be difrent. which will make it work faster/slower. the best way to check is count the teeth on the pto. he said to measure them and see how far the gear sticks out of the housing on both and that will get you close on how many shims you need to get it right. but you will need to put white lithiam grease on the gears to get the mesh clearences needed for max life of pto. you might need to add or remove shims until its right...joe
  • 1 month later...
