Went down to start truck today. Lightning bolt came on. Checked it. Gave 9-2
Sheet I have states-Power reset w/o key switch.
What does that mean, what should I look for?
2001 E-7 427
Thanks in advance, Ed
https://www.bigmacktrucks.com/topic/16748-code-9-2-what-does-it-mean/
2001 E-7 427
Basically it means the modules lost power while the VECU was still reading voltage at the ignition. Usually it's caused by bad batteries or loose connections.
Thanks. Truck has batteries that were raised here in the south-Don't like cold weather .
When I went to start, it did hiccup and then fired up. Will check battery conditions
