I have a 1972 mack CF611 that has had the pump removed from it. It has the 5 speed transmission in it. I am interested in switching to a straight drive shaft so I can remove the trasfer case that is left over from the pump. Right now the transfer case ks mounted in there just because the driveshafts need it. Are there any models on the 600 chasis that would have a single straight drive shaft that I could put in place of what I have?
Thanks,
Matt
https://www.bigmacktrucks.com/topic/16788-drive-shaft-interchangability/
