gday, i looked for switch near the brake valve itself but cant find it. is it typically in one location on the b's, mines a b613. any info would be appreciated, also any pics if available.
cheers ellis
Hi Ellis, most B series brake lamp switches I've seen are on the left side of the truck just under the rear of the cab, or barely under it. The ones I've seen are inside of the frame rail. This of course is for a left hand drive truck and I don't know about right hand driven types but assume near the same.
As Rob said, in the frame rail...mine had two air lines, one from brake valve, one from column trailer valve, and two wires,
you should be able to track it by any of these three.
Good luck
