The parts book for a gasoline powered trucks lists the following,
Jack 8 ton,
Wrench, socket
Wrecch, axle (SW44)
Handle,socket wrench
Bar, pilot
Socket,Spark plug wrench
Extension,Spark plug wrench
Handle, Spark plug wrench
Wrench, Engineer's 7/16x1/2
Wrench, Engineer's 9/16x5/8
Wrench, Engineer's 3/4x7/8
Wrench, adjustable
Driver, #2 phillips screw
Driver, #3 phillips screw
Driver, 3" screw
Driver, 6" screw
Hammer
Pliers, 8"
Padlock, tool box
The early LT's had the battries on the LH side the RH side is the tool box. later truck batteries both sides.
FW
https://www.bigmacktrucks.com/topic/16914-mack-tools/#findComment-68756
