Anyone know who carries or where to get Thrust washers for an End673? I assume they arent available from Mack anymore nor is a Main Bearing Kit? Took a good running 673 apart to clean and paint it and found part of a thrust washer in the oil gallery around the air compressor drive gear. Found the other half in the oil pan. would like to just slip a new set of washers in without screwing with the crank or Main caps as this engine has has the top end gone thru and ran pretty good. Also dont wanna put much money into an old 673. Thanks , Matt
https://www.bigmacktrucks.com/topic/16942-673-thrust-washers/
I think they're still available from Mack. Federal Mogul/FP Diesel should have a part equal to OEM quality if the parts aren't available through Mack. PAI to maybe.
https://www.bigmacktrucks.com/topic/16942-673-thrust-washers/#findComment-68892
