Do you turn signals work normally as in left and right? I mean not using the 4 ways? If you have a problem with the turn signals also, look for a grounding problem. If the turn signals work normally and the 4 ways do not, look for a flasher being bad as most vehicles do not share the same unit.
https://www.bigmacktrucks.com/topic/16985-4-way-flashers/#findComment-69113
