Brian
I will assume you will be going north on 495 from either the mass pike , 290 or rte 9 . Go North on 495 and and get off on the rte 62 exit towards hudson. Take a right off the ramp onto rte 62 and follow it past the dodge dealer on the right and keep going until you hit the rotary. To this point will be about 3 miles off the highway. As you enter the rotary bear right towards Mcdonalds and ace hardware.
"you will see them both as you enter the rotary" then as you go by ace hardware which will be on your right take the first right which is park st. Stay on that road for about 1 1/2 miles and you will see the show on your right .
Jim !
https://www.bigmacktrucks.com/topic/180-mass-truck-show/#findComment-734
