Do you mean "Hale" pump?
Are you talking about the transfer case or the priming pump? The priming pump will use straight 30w, but most folks have gotten away from using petroleum based oil in this application as it dumps to the ground right next to a water source. You can use vegetable oil or even water to achieve the same result.
Try contacting either a local fire repair shop or Hale directly in Conshohocken, PA. for the correct transfer case recommendation.
