Has anyone had a bad experience with Biodiesel?
I am thinking about using B99 (99% biodiesel) but do not want to fry an engine to save a few pennies.
Mack had a service bulletin about Biodiesel, I think they only recomend 10 or 15% max, I'll try to find it and post it. Some guys in our area with new DPF equipped trucks used the 20+% biodiesel and it caused lots of regen problems. If it was a farm truck or a truck that wasnt used much I would not put any bio-diesel in it at all. I would only use it if I knew I was gonna run it all out before it sit to long.
https://www.bigmacktrucks.com/topic/18031-biodiesel/#findComment-73095
As Mackpro said, Mack and volvo issued statements regarding the use of biodiesel blends in their engines.
Here is a link to some other information from Stanadyne's website, a common position statement from the FIE manufacturers: http://www.stanadyne.com/docs/pubs/FIEM_Common_Position_Statement_2009.pdf
https://www.bigmacktrucks.com/topic/18031-biodiesel/#findComment-73097
Here's Mack Service Bulletin SB 210-043
SB 210-043 Use of BioDiesel Fuel in MACK Diesel Engines E-Tech, ASET, MP7, MP8 (June 28, 2007).pdf
I seem to remember that at one time higher blends were considered OK, but I think that was changed with the introduction of the DPF.
https://www.bigmacktrucks.com/topic/18031-biodiesel/#findComment-73099
Thank you Mackpro68 and rhasler.
https://www.bigmacktrucks.com/topic/18031-biodiesel/#findComment-73113
older manual motors will burn it with no with no problems, the electronic ones will run on b99 but will not make any horsepower, you need at least 25% mixture, to get your horsepower back, a 50 50 mix gives the best mileage and power it burns cleaner, so I am wondering how it would plug up the emission equipment on a newer truck
https://www.bigmacktrucks.com/topic/18031-biodiesel/#findComment-73173
