I started the task of changing a clutch, and while I was removing the shifting tower I looked around and noticed the top inside starter bolt had backed off. The starter is sitting at an angle and looks like it might be wearing out the teeth faster than normal. I am going to check the teeth on the flywheel and starter both. Is there anything else you think I should check out?
Edited by duggerinc
https://www.bigmacktrucks.com/topic/18070-it-pays-to-look-around/
