the rear cab mounts are unbolted from inside the cab. look behind the rear seats for two 3/4"? bolts.
the cab rests on rubber mounts simmilar to the front. The rear of the bam bolts to the frame crossmember or with a bracket that is welded to the crosmember. You may need a person below the truck to hold the nut wile you lousen the bolt.
Trent
