The ones that look best are the old F model. With very little work they will fit in the opening on a R hood. You can't buy them new any longer. But you can have an old one rechromed for about $325. That's what we paid for the last new one Mack had in the system about 10 years ago. Only problem with this type of grill is you need to remove the grill guard or mount it on hinges.
https://www.bigmacktrucks.com/topic/18245-r-600-grille/#findComment-74107
Would you happen to have any pictures of it? I was thinking of taking a t800 grille because I figure it's close and try to mount it to the inner cooler like the one that is on it but I don't want to take a $200 grille and cut it if need be just for it not to work
https://www.bigmacktrucks.com/topic/18245-r-600-grille/#findComment-74127
