I have crawled all around and found a bunch of numbers but nothing that I can make any sense of. Where do i need to look to find the number that wil tell me what size rears I have? Anyone have a picture of where this is located? Is the number stamped? Thanks.
Go to this link for a scan that I posted with this info.
http://bigmacktrucks.invisionzone.com/inde...?showtopic=1666
https://www.bigmacktrucks.com/topic/1835-stuck/#findComment-8891
I remember you posting that, I saved it on my computer. I just can't quite picture where on the rear the rear axle number is. I can see from the picture the bogie number is near a drain plug.
The rear axle housing # is stamped next to the filler plug on the rear of each banjo housing.
Here's a scan of the page showing the carrier #s on the flat pad at the front of the carrier housing:
Hope this helps
https://www.bigmacktrucks.com/topic/1835-stuck/#findComment-8893
