:SMOKIE-LFT:
Okay-I might have already done this,but here's the number I got straight from the build sheet for my truck:485GB145A. This doesn't cross to anything at the parts stores,so it's either superceded by another number or it's just not available anymore. If I still had the original filter,I could at least hunt one down by measurement,but as it is now,I'm not sure I can get a close enough match from just the housing measurements.
What filters are you other "E" owners using? My truck's a 1945 EH,the engine's an EN354. I've tried the NAPA number,but it's too small diameter and too short to use,but too long to stack two of. It was a sock type filter with a perforated steel cap on the top,which was domed. (It was so tightly fit or swollen in I had to pry the top off the cartridge and cut the rest apart to get it out.)
Sorry to bug you again about this,but I'll be financially able to buy a proper filter for it soon and don't want that to slip through the cracks again.
Thanks again for your help!
Speed
:SMOKIE-RT:
https://www.bigmacktrucks.com/topic/18411-mack-filter-number-interchange/
:SMOKIE-LFT:
I was referred to "Filter Mart",so I emailed the :mack1: part number and what information I have to them,got a reply this AM. THEY couldn't come up with a replacement either. :idunno:
Speed
:SMOKIE-RT:
