I have a '74 R model mack and am looking for 1 good shape fuel tank strap and 2 new rubber strips to go under the fuel tank straps. The front steel strap is 45" long to the t bolt head / plus the threads, and is 1 3/4" wide and is for a square alumium mack fuel tank.
Dont know about the straps, but here is a sorce for the rubber strips if you want new...
Tank straps
  • 5 years later...
Tank straps
Lesley, are those ones look the same as originals on your truck did?
When you contacted Watt's Mack (provider of the BMT website) at 1-888-304-6225 with your truck's model and serial number off the vehicle identification plate on the driver's door, what did they say?
I'm sure they can supply you with a new fuel tank strap (rectangular or round tank) and the 12AX128P150 rubber insulator (150 inch length - cut to fit).
Original post is almost 7 years old   bet he found them. :)
Edited by 41chevy
I found it.
Not them though. I found some web-store with rubber insulators for small van-boxed trucks. They offered cheap and described as for 2 inch straps. I bought two rolls from them and when recieved found out they are actually for 1.75. With the comment "they could be used on 2" straps"!!
Unfortunately when cutting SS strips I ordered them 54 mm, not 51 as I should for two inches. So those rubbers being possible (too hard and not nice) to put onto 2" strips have nothing of intend to fit mines.
So now the search continues.
