I was wondering if you guys that have B61s have problem with your accelerator pedal getting hot when you drive for awhile, mine gets hot enought to heat the bottom of feet up, i figgerd it was because the linkage was so close to the back of the engine and above the transmission, i have a 300+ with a 13 speed roadranger. thanks Ron
https://www.bigmacktrucks.com/topic/185-accelerator-pedal/
Must be the 300+?? Mine does not get warm at all.
What for insulation do you have?? Anything more than rubber mat? I have carpet, rubber and 1" jute to help with noise.
https://www.bigmacktrucks.com/topic/185-accelerator-pedal/#findComment-702
I have a 673C 250 hp and have had her banging away for long periods on some pretty hot days. My foot was no hotter than the rest of me! I run with a 15 speed RR and have some pretty good insulation on the firewall.
Whatever rubs your buddah.
The Mack E Model Registry - 103 entries
The Mack A Model Registry - 14 entries
https://www.bigmacktrucks.com/topic/185-accelerator-pedal/#findComment-906
