Got a few questions:
My 74 RL700 is needing replumbed in the brake system. The truck is loaded with Strat-O-Flex lines that are hard and brittle. I've decided to completely replumb with plastic and brass. I'm wondering if the brake lines from the bulkhead fittings on the steer axle should be plastic, or rubber air brake hose? One of my trucks has plastic lines in this application, and a couple others have rubber line. On this truck which has wedge brakes, the quick release valve for the spring brake chambers is on the frame rail as is the relay valve for the service brakes.
I know plastic air brake line is durable enough to take the constant flexing of the application but I'don't know if it's legal or not.
Anybody aware of DOT rules concerning this?
Thanks,
https://www.bigmacktrucks.com/topic/18547-air-brake-plumbing/
  • 2 months later...
As far as I know plastic is not legal. Rubber is the only way to go on any flexible connection. Plus plastic will kink on the steer axle. Plastic will break with extended flexing.
Hi, Australia has very tuff laws on this sot of thing, safety first. plastic was legal years ago for memory, then they stopped it some time later due to the hose been easy to kink, in saying that there still is a few trucks out there that have plastic. flexi rubber hose would be the way to go on every thing from chassis to axles, where a moving part meets a non moving part the rubber is the one.
Grant
https://www.bigmacktrucks.com/topic/18547-air-brake-plumbing/#findComment-78870
Some plastic or nylon has a braid in to resist kinking meets our standard in Australia but the cheaper non braid does not meet the tube is marked with a J no. from memory can't remember the no. and AS standard for our hose but rubber DOT hose needs to be used between chassis and axle where there is constant flexing and movement in suspension and steering Gearbox
https://www.bigmacktrucks.com/topic/18547-air-brake-plumbing/#findComment-79728
  • 1 month later...
I used plastic on the rear axle of my truck when it was still spring(don't move much). I can see air ride being more of a problem, and I used rubber on it now. Heard it was illegal.
https://www.bigmacktrucks.com/topic/18547-air-brake-plumbing/#findComment-82333
