Superliner On Ebay
David
If the driver comes with the truck, consider it sold.
http://cgi.ebay.com/...=item230fc1ceb0
Even if the driver is shaped like a pear?
Trent is a lot closer than I but if you're interested I'll drive up to view it for you.
That is called "iceberg" sir. You only see the top 10% above the surface and the majority of the mass is below eye level. The truck is less likely to cause problems and will be cheaper to use.
#1 on A-model registry
