I am dealing with a 2000 etech with 230000 that on cold start has what sounds like timing knock or firing early when the engine warms up it can still be heard just not as loud. the driver said the sound a year ago was not very loud it has been progresivly getting worse i remember reading some where that mack had problems with there cams i removed the pumps and looked over the cam there was nothing wrong with that the injectors were replaced as to a thought that this might be a problem i am at a loss were to look it brings up a code for cylinder number 1 abnormal frequency any thoughts or sujjestions would deeply be apreciated
https://www.bigmacktrucks.com/topic/18692-2000-etech-e7/
It may be a bad injector
To check which hole breifly short out each unit pump one at a time untill you hear the knock go away. If you find its,eup 1
Replace unit pump one! But note the cal code on the side of the new pump as it needs to be installed in the computers brain at a later date by a Dealer..\
Also check the pan plug for brass I have seen several trucks of this era with the odd bad wristpin bushing.
https://www.bigmacktrucks.com/topic/18692-2000-etech-e7/#findComment-75960
The injectors have been replaced as that was thought to be the issue by shorting out the pumps will that act like loosening the injector lines on mechanical engines Sorry if i ask some redundant questions but i am 19 and have a far better understanding of cat engines and equipment looks like a very similar system just want to learn more about it never know when it will come in handy
https://www.bigmacktrucks.com/topic/18692-2000-etech-e7/#findComment-75962
[/quote ]
Yupper , Same as loosening a line just not as messy :) If you identify number 1 as the culpret change the eup if you are sure that the injectors are fine !
Or if the problem persistsOR it is not No #1 I would pull the pan and and check thew ristpins on the one you do find!
My opinion
https://www.bigmacktrucks.com/topic/18692-2000-etech-e7/#findComment-75963
here is an update on the situation got back to the shop started truck ran good for the first five seconds started to go under a load cracked the injector line for number cylinder number one, engine ran smoother cracked number two heard a distinct cutout, switched pumps between one and two did not help the situation problem has been narrowed down to number one cylinder removed wires from pump checked for an open circuit on the wires it was open leading me to believe that it is a mechanical problem. in the cylinder or in the injector seat or in the line fittings if they are cracked i am also going to pressurizd the radiator and start it to see if there is any white smoke out the exhaust. Is there anything else that should be checked out?
https://www.bigmacktrucks.com/topic/18692-2000-etech-e7/#findComment-76028
You had a code for no#1 EUP Which is now in number two! Correct? You need to put that origanal no 2 pump back in its hole as it is calibrated for that hole and either replace the eup or replace the injector!Remembering you had a code for #1 eup.
My opinion!
https://www.bigmacktrucks.com/topic/18692-2000-etech-e7/#findComment-76066
