i have a bad igniton switch would this draw juice from the batteries?? please help
thanks
Tom
Certainly depending on what the ignition switch is powering. I'd bet you have other problems in the electrical system but would not rule out that switch. Take the wires loose from the backside and see if the charge depletion still exists. Or, place an ammeter in series with one of the battery posts and cable to check for parasitic draw.
