Getting better and better at shifting...can cruise around no more than 1600 (crusing 35-45 on the back roads)
shifting up and down with ease (no clutch)...
Question is...how in the hell do people shift the main and compound when goin up hill from a start...no matter how fast I
shift...by the time the RPM's fall to shift the main, the truck is almost stopped! The old hands must have been masters!
https://www.bigmacktrucks.com/topic/19008-shifting-progress/
With a load sometimes you didn't. That is part of the reason trucks of the past were so slow as compared to today's. Practice makes perfect but sometimes it can't be done.
https://www.bigmacktrucks.com/topic/19008-shifting-progress/#findComment-77533
I haven't figured that out completely either, most of the time I just run the gear I'm in till I get to the top. No sense trying to tear it up. I have found that it is quite a bit smoother if I run about 1700-2000 until I get up to my cruise speed.
I agree those guys that drove these things for a living had skills that will never be seen again. The new stuff is like driving a car.
https://www.bigmacktrucks.com/topic/19008-shifting-progress/#findComment-77539
Starting from a dead stop at the bottom of a hill with a two stick trans. is indeed difficult to master,but not impossible....trick i use is to start in a low enough gear to let you climb the hill,and usually you only need to make one progressive shift in the compound. Personally i do not use the clutch,especially when shifting only the auxillary trans. it does take practice,but when you get the hang of it,its like second nature. It's kind of hard to explain something like this without actually being there in person,but i hope this is of some help!...............Mark
https://www.bigmacktrucks.com/topic/19008-shifting-progress/#findComment-77583
