loaded a load of plastic jersey berriers today, thought i was gona have some good luck, they are about 4ft. tall and weighted mabe 1500 lbs. going to brigham,ut. at 2 bucks a mile.
as soon as i was strapped and ready to roll jumped in and seen the lightning bolt and showing 10 volts.
it coulda been a lot worse, i was only 8 blocks from f@c mack in st.louis,
its not mcbride by a long shot, but maybe they can get me going??????
https://www.bigmacktrucks.com/topic/19073-alternater-maybe/
Yep, probably an ALT. Yours was due for one if it was an orignal.
https://www.bigmacktrucks.com/topic/19073-alternater-maybe/#findComment-77777
alt was only putting out 10 volts.
got it replaced, and turbo filter, vgt spray lube.
this is where i miss mcbride, gona take these guys an hour or 2 to get my paperwork ready before i can leave..
im spoiled................
https://www.bigmacktrucks.com/topic/19073-alternater-maybe/#findComment-77778
Im heading to Florida for a week, If ya need me call anyway! On your idea on the EGR valve switch breaking the circuit , either wire will work.
https://www.bigmacktrucks.com/topic/19073-alternater-maybe/#findComment-77790
