I am trying to find the crankshaft specs for my 1991 E-7 350 Mack says the rod journals are suppose to be at 3.248 mine are at 3.332 with std. bearings,I plastigaged the new bearings at .003 to .004 "what am I missing here" this is about .015 diffrence it's been running like this for over 200,000 miles the Motor was remaned by Mack the new bearings have the same numbers as the old ones,I had a machine shop come out to measure the crankshaft
https://www.bigmacktrucks.com/topic/19101-crankshaft-specs-e-7-350/
This is from the E7 Manual. I've seen instances when the manual didn't have the correct measurements listed. Assemble the rod, bearings, and cap and measure the bearing ID with an inside micrometer or a "snap" gauge and outside micrometer and compare to your measurement for the crankpin to verify that you have correct running clearances.
CONNECTING ROD
Length between centers 10.4375 in. 26.5113 cm
Cap angle 35 degrees
Bore for bushing 2.4355–2.4345 in. 61.8617–61.8363 mm
Burnish bushing to 2.2305–2.2275 in. 56.6547–56.5785 mm
Finish bore to 2.2504–2.2500 in. 57.1602–57.1500 mm
Crankpin bore diameter — as bored 3.4305–3.4297 in. 87.1347–87.1144 mm
— reassembled 3.4309–3.4294 in. 87.1449–87.1068 mm
Bearing ID in place 2.9993–3.0013 in. 76.1822–76.2330 mm
Journal clearance 0.0012–0.0054 in. 0.0305–0.1372 mm
Side clearance 0.007–0.014 in. 0.1778–0.3556 mm
Twist within 12 inches (30.48 cm) 0.010 in. 0.254 mm
Bend within 12 inches (30.48 cm) 0.004 in. 0.1016 mm
CRANKSHAFT
Crankpin journal OD 3.248–3.247 in. 82.4992–82.4738 mm
End play at No. 4 main 0.004–0.013 in. 0.1016–0.3302 mm
Main journal OD 4.4974–4.4964 in. 114.2340–114.2086 mm
Journal out-of-round or taper (maximum diameter) 0.00035 in. 0.00889 mm
Max. Runout at No. 4 journal (shaft supported on No. 1 and No. 7) 0.007 in. 0.178 mm
