If you have the serial number, contact the Mack Museum and they can provide you with the buuild sheets. The build sheets will give you the part number and the folks here at Watt's can help you figure out if new stock is available (probably not). If it is, you are lucky and it will not be cheap. Your motor is probably a 707B and not a hard issue to find some parts for.
Art
Art Lawrence
arthur.lawrence@firetruck.com
Gaithersburg, MD
182Fireman,
The first B85 Firetruck was built in 1954, you may have an 1953 L85 Pumper, or a later year B85 Pumper, either way the serial number will help determine what you need. Most B85 Pumpers had the 707B thru about 1960, then started with the 707C. Once you confirm which 707 , I am sure we can find someone that has an exhuast manifold.
Firemack
