Why would a truck heater only blow cold air?
Are the valves turned on under the hood? There should be shut off valves on the heater hoses where they attach to the engine.
Also check the cable or air operated heater control valve inline on the heater hose to be sure that is moving when you move the lever in the cab.
Gregg
https://www.bigmacktrucks.com/topic/19322-about-truck-heater/#findComment-79196
