My rear housings are SWD5701, they have maxi brakes.
I want to put modern cans on...from what I can see, the mounts for the cans and shaft bolt on to the
ends of the housing. Can I simply find a more modern SWD5701 and change the brake mount?
Are there other rear housings that will swap, that is, is the bolt pattern standard on similar, but later model axle housings?
Thanks
https://www.bigmacktrucks.com/topic/19366-rear-end-parts-interchange/
Thanks
Install some 24/24 spring brake chambers on the existing mounts. Clearance is close but they will fit.
