Engine oil pan drain plug-55 lb ft.
transmission drain plug 25-30 lb ft.
transmission fill plug (T300 with o-ring seal)-35-50 lb ft.
Torquing the NPT pipe plugs is not critical, make sure they're tight enough not to leak or to unthread by themselves. Don't overtighten the o-ring sealed transmission fill plug, it takes alot more to remove them than it does to reinstall them.
