My truck does not have a low air warning device. I figure it was not a requirement in 1961 so it shouldn't be a big deal. But I plan on cleaning up the air lines soon, few leaks behind the dash spewing oil out little by little, its a mess back there. In the process I figure it would be good to have a low air warning wig wag or similar device.
were low air warning devices required in 1961?
Do I need to update the system and add one? (from my tires post, 41 chevy posted a list that points to yes)
What low air warning devices were common in those days? I know of the wig wag that is mounted to the roof and would drop down if the air was low, were there any others?
-Thad
https://www.bigmacktrucks.com/topic/20494-low-air-warning-device/
The required safety devices in the inspection is relative to the year of your truck. You are required to have what was required in 1961. My mixer has a Low Air warning light that was added next to the gauge. It is wired to a pressure switch mounted in the primary air tank. The wiring and switch are definatly an add on. Paul
