I had one and it held the clutch brake so well that if you ever let the truck roll while you were holding the clutch, it would shear the tabs off the brake. I know that was driver error, but it was easy to do and not so easy to replace the brake. More stuff to keep working too the way I look at it. Trey
https://www.bigmacktrucks.com/topic/20555-air-assist-clutch/#findComment-85771
  • 4 weeks later...
  • 4 years later...
1 hour ago, Clifford Turner said:
Where can i find the air assist delete kit?
Call Barry at Watts Mack 1 888 304 MACK  Head of Parts Department and this site.
Edited by 41chevy
https://www.bigmacktrucks.com/topic/20555-air-assist-clutch/#findComment-337042
On 18 juin 2016 at 1:55 PM, Dirtymilkman said:
Maybe mine is different, but a 2015 with 150,000 miles and never an issue. Clutch is used a lot too
They usually start to leak or mechanically fail 3 or 4 years in. Had a 2014 Titan in the other week with a complete air assist fail.
Like everything, some work and some don't.  But lowering your exposure to a fairly common failure is always a win
https://www.bigmacktrucks.com/topic/20555-air-assist-clutch/#findComment-337225
  • 4 months later...
On September 13, 2011 at 8:41 PM, Mackpro said:
Please just say NO. Mack had so many complaints they came out with a kit to change it back to the orignal cable style.
I contacted Barry at Watt's & he got in touch with Mack & can't find anything on a kit; if you can get me a # on it I would be greatly appreciated
thanks
https://www.bigmacktrucks.com/topic/20555-air-assist-clutch/#findComment-350123
  • 3 years later...
