I was wanting to know if there is a way or special tool, etc... to hold the lifters up while you slide the cam out and in on an e-tech? The heads will be off and the pan will be off, doing an inframe. I think i might have a lobe wore off and after i check it to be sure i just didnt want to have to pull the engine just to turn it upside down as my service manual says. I would much rather just set the cooler and radiator in the floor. BERFORE SOME FUNNY MAN SAYS IT, IM NOT FLIPPING MY TRUCK OVER!!! LOL! Thanks in advance for any and all help.
On the old 673's an the Maxi's, we would coat the mushroom tappits uith a heavy wheel bearing grease, slip them in gust before sliding in the cam, it has to be a heavy sticky grease an it would hold them in place until you got the cam in, I'm told some guys even used to cut down clothes pins to hold them but I've never done it that way.
BULLHUSK
mack has special magnets to hold up lifters. but you can use regular extention magnets. if you get ones that swiel on ends just put piece of hose over swivel, tomake it easier to put on lifter. just use cloths pins to hold magnets up.
Tom ~ Parts & Service Specialist
Watt's Mack Sales, Inc. 1-888-304-6225
uh...well, just never mind then, if you don't want to turn the truck upside down...that's the only ideer I could come up with.
I like the magnets and clothes pins idea. I'll go the the cheap tool store and buy 12 of them cheap telescopic magnets and pull the lifters up and then clip a clothes pin on the magnet and let it rest on the block. I knew I was over thinking it. That was a heck of an idea! Thanks a million!
The special tool is Kent Moore J377720-A (might be a different letter at the end now). It's basically plastic rods with strong magnets glued to the ends and a set of large plastic clips. Pretty sure you could buy the parts needed to build a set at a hardware store for far less than Kent Moore wants for them.
