Saw these pictures of some RW's with what looks to be arabic? writing on them,also notice the position of the headlights,some export only option? never seen that particular set-up before,looks a little odd,after seeing "normal" Superliners for so long............Mark
post-5836-0-77393200-1316311028_thumb.jp
https://www.bigmacktrucks.com/topic/20646-terrorist-rws/
Mark, It's definitely the correct color!!
Ernie DS
https://www.bigmacktrucks.com/topic/20646-terrorist-rws/#findComment-86251
Seems a fellow on ATHS knows the reason for the dropped headlights............seems it's a regulation over there about distance from the ground? If I recall correctly?
https://www.bigmacktrucks.com/topic/20646-terrorist-rws/#findComment-86263
Abdul Sand and Gravel
I thought it was Achmed Habib Abraham Sand and Gravel.
Must be thinking of something else?
https://www.bigmacktrucks.com/topic/20646-terrorist-rws/#findComment-86268
That's the Superliners I was thinking of- the British magazine "Truck" had an article on them. Really missed that mag, was a first class publication and seemed like they liked Macks. There road tests were the best I've seen- they actually tested the trucks with loaded trailers and over a standard route so you could compare results between trucks.
https://www.bigmacktrucks.com/topic/20646-terrorist-rws/#findComment-86477
They are Israeli,they've had a preference for Dogs since the 50's. Only Morty can sell sand to APU :) Paul
https://www.bigmacktrucks.com/topic/20646-terrorist-rws/#findComment-86505
Don't know how old that photo is but I seen the green and white Superliner in Jerusalem, Israel in November of 09.
I was on a tour bus so didn't get a photo but thought it was pretty neat to see. There were a bunch of DM series dumpers over there also.
https://www.bigmacktrucks.com/topic/20646-terrorist-rws/#findComment-86510
