I was hoping someone has a answer for this. I have a 1964 b-67 twin screw. I'm getting ready to reinstall the torque rods but need a few parts. I need some springs to hold the canvas to the rod. The spring and (washer, cap, spacer whatever it is) to apply tension to the ball. and maybe some other stuff that decides it needs to be there. These are the old rods that look like big tie rod ends. Or better yet can I use some parts from the steering drag link off the parts truck?
Or should I get the Meritor custom fit all that looks like modern tie rod ends with a sleeve in the center that you weld?
This is one of the final this to do to get the rear of this truck restored. I'm still working on pics. to post and there will be alot. Steve.
https://www.bigmacktrucks.com/topic/20678-torque-rods/
