I need some help guys,
I think I have found the same PTO that I have or dang close to it.
http://cgi.ebay.com/ebaymotors/DANA-Chelsea-PTO-100XRBQX-SM465-trans-Chevy-GMC-C30-/330618288846?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cfa62bace
I know its a 6 bolt PTO , problem is im looking for the plate to put on when I pull the PTO off. It leaks a bit of oil as you can see and I dont use it so.. its coming off.
Would this IH part work or where could I find the plate and gasket thats correct for my truck?
http://cgi.ebay.com/ebaymotors/International-NEW-PTO-Plate-and-Gasket-13156H-FREE-SHIP-/250780038771?pt=Other_Vehicle_Parts&hash=item3a63a7b673
Heres pictures of mine. Jay
post-2596-0-17110300-1317331110_thumb.jp
post-2596-0-63000300-1317331115_thumb.jp
post-2596-0-45555700-1317331122_thumb.jp
post-2596-0-24206100-1317331165_thumb.jp
post-2596-0-98493800-1317331170_thumb.jp
Good idea pulling it off. I had a 12 speed the owner wanted rebuilt due to whining noise at road speed. It had a 6 bolt PTO that wasn't being used that was causing the whine. The 6 bolt and 8 bolt patterns are pretty much industry standard. Allison uses a 10 bolt pattern. Clean up all surfaces and seal with silicone, a gasket may not seal against the stamped metal cover.
Thnks! So a good place like Fleet Pride would have a 6 bolt PTO plate cover? I will use silicone, should I use the orange red high temp RTV or use the Permetex rear end differntial gasket silicone?
