Hello !
I'm in the process of buying a Mack RD688S 1895
E6 350 (sligh oil leak on the rear side of the motor( helper side ) but doesn't seems to leak
too much . never been reworked
TXL1070BT 12 speed Mack tranny
CRDPC92 front (rear axle)
CRD93 rear (rear axle)
700,000 km ( 438,000 miles )
front axle 18k
rear axle 44k
dump body in pretty good shape
truck body need a bit of TLC but it is still very good (at least to my knowledge) ,
tires are very tired .
frame is in a good shape
suspension is hendrickson walking beam with leafs
anyone here as any comments or suggestions about this truck ?
please feel free to chimne in .
will be used sporadicaly thru the years but not like 7 days 24 hrs ,
guy is asking 13k
thank you for the help
https://www.bigmacktrucks.com/topic/20890-buying-a-mack-rd688s-1985/
  • 3 weeks later...
check the frame connector brackets in the front, the rear cab mounts and the front cab mounts. look real good to the left of the clutch pedal, back in the well by the door, the cab often cracks there.
other than that welcome to the world of back aches, head aches and blood in your piss! your and rd owner!
