Untop transmission there is air leaking from an exhaust tube. When I hold my finger over end of tube to block air, the selector changes. Of coarse when I let off the tube the selector changes back. Whats causing this, and what needs to be done to fix? thanks
https://www.bigmacktrucks.com/topic/20909-maxitorque-8-speed-multi-reverse-trans/
What I am referring to as an "exhaust line" is the line that is installed on a air valve that air "exhaust" out of. Exampe: susp. leveling valve has a short plastic line that just hangs there and hooks to nothing that air exhaust out of it. I have a line ontop transmission "exhausting" air off. Can't really tell were the plastic line goes to.
If that line is constantly exhausting air either your "selectair" valve, (shift knob) or the actuating cylinders needs rebuilt. It is just a set of "O" rings and possibly gaskets.
