Ok so i took your advise on the RTX-14609B. We swaped them out yesterday. My mechanic tells me that he's having trouble getting it in to gear from a stand still.He thinks it could either be 2 things.
1) the clutch pressure plate being bad or wrong clutch to begin with.
2) or the fly wheel is under spec and has to be replaced.
Can you please tell me what is the proper clutch for my application? I called mack and gave them my specs and they recammended the clutch we put in. I'll get that # for you soon. All i know is that it was a 14" ,4 paddle ,8 springs with 1400-1450 pounds of torque.
I have a glider kit so my VIN will be usless.
ENGINE 239GB5450P2 MACK E6-350
NEW TRANS RTX-14609B
Any info would be greatly appreciated guys.
Ok.. heres the clutch Mack recammended. Is this the correct one?
EATON 108050-59b
