I pulled the PTO off the truck today, well I dont know enough about them but im posting a picture of something with another gear on it that slides out also. Does that come off too or stay on the trans?
Other than that it looks like its about done. Just have to do alot of cleaning up then put some RTV , the gasket, and the plate cover back on.
Tel me what you guys think? Thanks.
post-2596-0-98585900-1319839320_thumb.jp
If you've got two nuts that went on them you can put both on one stud and tighten them up against each other and maybe get them out that way, or a pair of vice grips but that may kind of mess up the studs or they do make a tool to remove studs but it shouldn't be that difficult. If they are stuck you can heat that area a little and this should help. Trey
Im going to have to heat the lower one.
The top came out with a few bad words , two nuts, and a wrench. The bottom il get to tomorrow. Il heat it and try that. I used two nuts on it and started to strip one out.
